Speedometer shows MPH just fine but odometer is not turning.
I have it out of the car and took the cover off to see if anything obvious was wrong.
Nothing I can see without further disassembly.
Who do y'all recommend to fix this?
Filling Station rebuild is a little pricey.
thanks again,
The odometer reels are gear driven so you can look for missing cogs, maybe a little more disassembly would be needed. If you need to send it for rebuild anyway it might not hurt to give a look. They will have to put it together after it is apart anyway.
J Franklin
Ask for your speedometer to be worked on and returned to you. You do not want another speedometer from somewhere else. They do excellent work. I had mine done there.
I've used D&M Restorations in Greenville, S.C. for many years....since about 1997. Does great work. Yes, they are all a little pricey Chris but if your in Burnsville how far is it to personally take it to D&M and chat with Mike face to face. He knows his stuff. He can also screen print speedometers if that is preferred way.
1937 Chevy 1/2 ton Pickup
1950 Chevy Styleline Deluxe Coupe
1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
