#397923 11/08/17 09:26 AM
Hi. The 1924 490 superior engine I plan to use in my 1924 Sedan seems to be very worn.
What is the max recommended bore considering "normal" rust in the cooling channels?
Olle
have a good block Dave 253-961-3052
Typical max over bore is 0.060". If bore walls haven't rusted too thin and there was little core shift during the casting process then 0.100" may be possible.
