#407463 05/02/18 05:56 PM
Hi folks, is it possible to remove and replace the cylinder from a 28 locking handle?
I can't see a way to do it, help please.
Whirrr whirrr chuff chuff de chuff........chuff......BRUMMMM!
There should be a pin crossways on the steel shaft. It needs to be carefully tapped out and if the lock cylinder is not frozen in the bore the whole thing should slide out the handle. Usually the cylinder (pot metal) swells locking it in tight and you could damage it trying yo get it out so be careful.
Thanks Cabboy, embarrassingly simple once you find it under the crud !
