Having issues with backfire when going down hill. Is this a timing issue or carb adjustment? Running regular non ethanol gas.
Check for an exhaust leak at the exhaust front pipe to the manifold. It's my understanding that when going downhill and not accelerating the unburnt fuel that passes thru is ignited by the air/oxygen being draw in thru the leak causing the backfire.
It is most likely to be an ignition problem (interuption) or a leak in he exhaust sysem such as the manifold gasket or manifold to exhaust pipe packing. Leaks in those areas allow oxygen to be inhaled on deacceleration causing gas build-up in the muffler to ignite.
Ignition wise possible condenser.
While you are at it check the timing too.
Might help for us to give advice if we understand that it is backfiring as you stated or is it after firing. Backfiring means that it is firing back through the carburetor. After firing is out through the tail pipe.
Did you mean backfiring or after-firing?
Hope you get it fixed soon,
That is a new one for me......
After firing isnt a common term but is a good 1 and often occurs as mentioned especially with late timing and exhaust leak close to the engine. Excess fuel still burning or reigniting in the manifold after the exhaust valve opens can cause it too under the heavy deccelaration conditons.
My experience with popping out the exhaust on deceleration is a lean condition. It's quite common on carburated engines when someone puts free flowing exhaust on without rejetting the carb. It can also be caused by air getting into the exhaust stream, mixing with unburnt fuel and being lit off by a hot spot. FYI oxygen does not burn, it supports combustion. I cringe every time I see a movie or TV show that shows oxygen tanks exploding. Obviously the producers/directors slept through science classes in school.
