#406406 04/11/18 10:33 PM
BobB Offline OP
I was wondering if anyone knows the color of the carburetor on 1932 Chevrolet? is it gray like the engine?
BobB #406407 04/11/18 11:11 PM
No. The 1932 carburetors (there were three of them, 212-S, 222-S, and the 235-S) all had black bodies. By the way, the 222-S was for trucks. The 212-S was the early 1932 version and the 235-S was the late 1932 version.
BobB #406410 04/11/18 11:33 PM
BobB Offline OP
Is the air horn painted or left plain aluminum?
BobB #406415 04/12/18 08:47 AM
The cast iron body and dust cover were painted black. The paint on the body is a utility grade dull black not flat or high gloss. the dust cover is much glossier but not a modern high gloss. Other parts are not painted. Some (like throttle arms) are plated and others bare metal.
m006840 #406419 04/12/18 10:31 AM
The air horn and the float bowl cover are pot metal, not aluminum. Also, the pot metal float bowl covers on the early two-bolt W1 carburetors are famous for warping.
I should have remembered "pot metal" as I swapped my carb out to a 569S due to a warped cover (5 years after repair) and a spare had an air horn that the pot metal completely fractured.
