Hi All,
I have been comparing three different camshafts as possible candidates for a higher compression 27 motor I am about to build.
I have a stock 28 cam has a 0.195" max lift on both intake/exhaust.
I also have a stock 27 camshaft that has a 0.220" max lift on both intake/exhaust
Lastly, I have a custom ground 28 cam with a 0.185" max lift on intake and 0.205" exhaust.
I don't have the equipment to measure duration, overlap, etc. so putting that aside for a moment, I understand the difference between the 27/28 max lift is probably attributed to the 1.0 vs 1.5 rocker arm ratio respectively. That said, it would seem that max valve lift would be achieved by putting a putting a 28 cylinder head on a 27 motor with a 27 cam - and I know that has been done many times before. I would say this achieves even more valve lift than the 28 motor.
Given the choice between these options, which cam is the better choice?
Thanks,
Coachman
