Posts: 125 |
Hello everyone, Do I have to pull the tranny to drop the crank enough to replace the rear main seal on a 235 motor? Thx
What year is the engine? If it is a 1955 or later a new design rubber seal can easily be installed. Just drop the pan and rear main bearing cap. If it is a 1954 or prior you will need to use a rope seal for replacement. The tough job here is replacing the top half with out stretching it out and ruining it.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I have changed the seal top and bottom on my two 216s in recent years with success. I did pull the transmission back and dropped the crank around 1/4". I use picture hanging wire tied on the end to pull it in. I also only use the new style seal sold by best gasket. I believe it is important to get the clearance in the main bearings down to minimums to have success with the seal.
