Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
My '51 has a right side visor, not installed after new headliner was added. I have attempted to install the "rod" which is part of the visor, into the visor mounting bracket, which is fastened to the roof / headliner area. The rod does not want to "connect", or interlock with the bracket. My fear is if I push too hard, the mounting bracket will break. Any suggestions welcome, I can take pics, if you believe pics would help.
Any assistance will be appreciated.
I believe it will be necessary to loosen the tension screw on the braket/support and spread the opening which is split.
I believe it will be necessary to loosen the tension screw on the braket/support and spread the opening which is split. Yes, that's correct Gene. I should have stated I loosened the tension screw, even tried to spread the bracket, where it is split, but still didn't work.
Apparently the rod has too large a diameter. Light sanding of the rod may remove just enough material for it to fit into the bracket.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Can you remove the mounting bracket and with the rod clamped in a vise tap the bracket onto the rod with a soft mallet. Putting the rod in the freezer overnight might also help to shrink the rod a little.
Apparently the rod has too large a diameter. Light sanding of the rod may remove just enough material for it to fit into the bracket. Thanks Chipper.
Can you remove the mounting bracket and with the rod clamped in a vise tap the bracket onto the rod with a soft mallet. Putting the rod in the freezer overnight might also help to shrink the rod a little. I like the freezer idea for the rod. Thanks.
Can you remove the mounting bracket and with the rod clamped in a vise tap the bracket onto the rod with a soft mallet. Putting the rod in the freezer overnight might also help to shrink the rod a little. As a follow up Steve, I put the visor in the freezer overnight, early this A.M. I took it out, installed it perfectly, with no hiccups. Thanks Steve.
Glad to hear that it worked for you.
