Posts: 2 |
On a 64 3/4 ton are the inner tie rod ends the same as the inner tie rod ends on a 1/2 ton?
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
What is the designation, C10 G10.....? My book only lists them like that John 348/340 HP
John
Posts: 2 |
OK...I have a 64 C20 3/4 T truck. To complete my front end rebuild I need inner tie rod ends. The filling station only lists them for a 1/2 T and I don't know if they are the same on 1/2 and 3/4. I also need an idler arm and a pitman arm. The picture shown in the filling stations' online catalog for the idler arm looks right but the picture for the pitman looks different than mine. My pitman arm has a ball joint on the control arm end whereas the pictured pitman does not.
This is from a Chevrolet parts book printed in 1966. Seies 20 and 30 are the same, w/o 4wd the book says 8 5/8" from socket center to end. John 348/340HP
John
