Posts: 103 |
Very strange. I parked the 31 Coupe last night and everything was fine. I checked the oil and it was full and clean. This morning I back it out of the garage and there was so much coolant in the oil it was coming out the dipstick hole. Milky white liquid. It was 2 inches or more above the full mark.
What could have failed to cause this massive leak in a matter of 2 or 3 minutes ?????
I'm guessing an internal casting failure maybe from rust. I have no idea. It sure is not a small leak from a head gasket. I can't believe it filled the oil pan in a matter of a few minutes.
Sad face.
Posts: 32 |
Sorry to hear about your problem. You could pressure check your coolant system, and try to pinpoint the leak. Pulling the spark plugs may also yield more information.
