#404059 02/26/18 11:52 AM
RonPenn Offline OP
I was just wondering if it is OK to run unleaded gas in my 32 stovebolt engine or should I be using an addative?
1932 4 door Special Sedan 1916 490 Touring
RonPenn #404061 02/26/18 12:05 PM
Sure! Your car has a low compression ratio, so you can run unleaded in your 1932 since that is basically what it ran on back in 1932. And, no lead additive is needed.
RonPenn Offline OP
Thanks Junkyard Dogpu3dtn
RonPenn #404096 02/27/18 02:59 PM
Below is a link to an interesting letter. It was written by Louis Chevrolet in 1931, and he talks about octane ratings. His 333 inverted aero engine was being evaluated for military use by the War Department. According to his letter, regular octane ratings in 1931 were 68 or 69 on the rating scale.
Louis Chevrolet talks about Octane Ratings
2001 Z-28
Arctic White 6-Speed
No Options
https://www.ChevroletBrothers.com/
RonPenn #404097 02/27/18 03:37 PM
The only reason lead wad added to gas was to make it burn slower, The gas at that time was not refined too well and it higher performance higher compression ratio engine , the engine would "ping" under laoad. It was cheaper to just add lead rather than refine the gas.
In the '20's, '30's and '40's regular grade of gas did not contain lead. The Ethyl grade (leaded) had warnings on the pump about the danger of the lead and warned against it contacting your skin or using for a cleaning solvent.
Chev Nut #404098 02/27/18 03:43 PM
Yes indeed, lead is pretty nasty, and can cause all sorts of health problems.
One of the reasons why octane ratings were lower in the 1920' & 30's was because compression ratios were lower.
2001 Z-28
No Options
