#403862 02/21/18 07:32 PM
Hi have a relative that has a 1936 master 4 door and the frame has been hacked up they've been looking out for replacement frame and they found a 37 chevy frame will a 37 frame fit underneath a 36
juanz1947 #403863 02/21/18 07:42 PM
There is an all new frame and body in 1937 - will not fit.
A 1936 Master frame will only work. Also if the car has knee-action the frame from a 1936 Master with leaf springs will not work That was a rare combination.
juanz1947 #403866 02/21/18 10:20 PM
A 1935 Master frame will work as well but you will have to make provision for the mounting of the master cylinder as the 1935 uses mechanical brakes. Otherwise pretty much the same frame.
RonDaw
345chevy #406107 04/05/18 05:39 PM
I would look at your frame carefully. Take photo's so you can post them on emails you send to persons who have frames they want to sell. Before you buy I would make the trip to see it in person. Compare your photo to the one you are looking at to be sure. Lots of folks say they may have one but they really don't know what they are talking about.
