Posts: 72 |
Chevgene, The number stamped in my block behind the distributor F517B Does that tell whether the engine has hydraulic or solid lifters? Thanks...Richard
If its a 1958 engine - F made in Flint 517-on May 17th B-235 Power Glide car
It would have had hyd. lifters when it left the factory.To install solids the cam would have to have been changed later.
Posts: 72 |
Ok Chevgene, thanks, It's firing now so I'm in the ballpark.
