Posts: 120 |
Hello everyone, My name is Brian, I live in a small town in Ohio and I'm 28 years old. I've had my 1926 Touring since July 2017 and I just haven't found the time to share it until now. I believe the car has been maintained and worked on, but has never been restored. Most of the wood is in excellent condition, it's never been painted, the electrical system is somehow working and I've gotten it to run and drive without much effort. Here it is the day we got it home: My grandfather discovered the car in the Generator and Distributor after we got home from the Mid-America Four Cylinder Tour back in May 2017. After a couple of months of speaking with the owner, I placed a deposit and my father and I drove 600 miles from Piqua, Ohio to Kansas City, Missouri. The car had been kept with a friend's private collection in a climate-controlled warehouse since about 1985 or 1986. I think that the history of this old Chevy is just as interesting as the car itself. It was found by a gentleman in the Veteran Motor Car Club of America in an open side of a barn near Chilhowee, Missouri. He purchased it for his father just before Easter in 1956. It was rarely driven because he could not decide if it should be restored or not. He wiped it down with an oily rag and left in his basement garage. The gentleman that I got it from found it in 1980, buried in a pile of boxes, furniture and other items. After getting the car home, he put in a battery and a new set of points in the distributor and the car ran and drove. It was used occasionally for car shows, visiting his children’s friends at school and even letting his young son drive it. Sometime around 1986, the car was allowed to be stored in a friend’s climate controlled warehouse in Kansas City, Missouri where it sat until I found it in July 2017. I've been working on the car, but there is still a lot to do. The original honeycomb radiator had a couple holes in it and it was full of calcium. I had a brand new honeycomb core installed with the original tanks. I also rebuilt the water pump. I went through the entire fuel system. Cleaned the tank, blew out the lines, rebuilt the Stewart Warner vacuum pump, added a couple inline filters and rebuilt the Carter carburetor. The original coil was a little weak on the high tension side, so a new modern-style 6v coil was added. Plugs and wires were also replaced. Adjusted the valves. I dropped the oil pan to clean and inspect, changed all fluids and lubricated all of the chassis and suspension points. I cleaned the interior and removed at least two 1920's diseases. I also added some egg crate foam on top of what's left of the seat covers and put Indian blankets over them. To keep the blankets from blowing out, I used a number of female-threaded neodymium magnets. A small screw with a washer goes through the blanket and it sticks to the steel body. I've already steam cleaned the wheels, but I still need to finish coating them with linseed oil. They are a little dry and therefore loose. The oil will tighten them up. I can also inspect brakes while I'm in there. The tires are from Montgomery Ward. I had never heard of them before, but the older folks that I share the car with have had chuckles after I tell them. I haven't looked for a date on them, but they're decades old. A little cracked on the sidewalls, but the tubes hold air! I will replace them in the spring with Goodyear black walls. The exhaust system is original, I think. It only goes just beyond the transmission. I will replace it with a system that goes to the rear bumper. I still need to check out the steering box and try to tighten it up a bit. I also plan on putting a new wiring harness from Rhode Island Wiring Service in the car before spring. To help preserve the patina, I covered the entire car (top and bottom) with Gibb's penetrating oil. It lays on really nice and gives the metal a great look. It doesn't have any silicone in it, so if I ever decide to restore this thing, I can strip the oil and paint over it without worrying about failure. I'll be posting updates as I go. Let me know if you guys have any questions. Thanks for looking!
Posts: 1,894 |
Wow! Your car looks really, really solid. Great find!
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
Very nice, I like what you are doing.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Brian, Are you going to drive it on the VCCA 4 cylinder Tour in Iowa in June? It sure would be a hoot! to see it in person.
Posts: 120 |
I will be in Iowa with my grandfather and his 1927 Coupe, but I will not be bringing the Superior along. Leaving the car out in the elements will not do it any favors, unfortunately.
Posts: 34 |
Hi Brian,
Since your vehicle is original can you take a photo of your engine compartment (both sides)? A picture is worh a thousand words.
Thanks.......Rob
Posts: 120 |
Posts: 120 |
Are you looking to see something specific? I don't have any decent pictures focusing on those areas... However, I have the following pictures that were given to me before I purchased the car. I may be working on it tonight, let me know what you want to see and I'll do my best to capture that.
Posts: 317 |
I absolutely love this. Can't wait to meet you and the car.
Jeff
1925 Superior K 4 Dr Sedan 1966 C10 2003 Silverado 1500 HD
Posts: 34 |
Hi Brian,
Thanks for the pictures, I appreciate your time. I need some more help:
1. Is the firewall painted black or is it body color?
2. Is the top of the vacuum tank painted black?
3. Is the oil filler tube engine color or black?
4. Is the heat pipe from the exhaust to the carb painted?
5. Can you take a picture of the throttle linkage from the bottom of the steering column to the carb? There appears to be a spring where the rod connects to the carb.
6. Can you take a picture of the distributor linkage from the bottom of the steering column to the distributor?
7. Is the brass carburetor fuel bowl painted black or is it just tarnished in your picture?
8. Is there a spring running from your carb to the firewall?
Thanks for the help..........Rob
Posts: 1,213 |
The original bearing numbers for your front wheels are: Inner bearing complete: New Departure 909002
Outer bearing complete: New Departure 909001
CJP'S 29
Posts: 120 |
Hi Brian,
Thanks for the help..........Rob Cool. I'll take some pictures and give you some answers. The original bearing numbers for your front wheels are: Inner bearing complete: New Departure 909002
Outer bearing complete: New Departure 909001 Fantastic! Thanks for the info.
#1 = body color #2 = all of the vacuum tank is painted black #3 = engine color #4 = No #5 = let's hope someone posts a picture #6 = " " #7 = polished not painted #8 = yes
Note that the engine is equipped with an aftermarket heat exchanger for the passenger compartment. Chevrolet did not provide a heater for the 27 and earlier with the single exhaust head. A heater was provided for the 1928 which is a "dual" exhaust.
Brian, Ask your grandfather about right front wheel bearings. He is an expert! The story will amuse you.
Posts: 120 |
Brian, Ask your grandfather about right front wheel bearings. He is an expert! The story will amuse you. Oh yeah! I've heard that story. Ha!
Posts: 120 |
Note that the engine is equipped with an aftermarket heat exchanger for the passenger compartment. Chevrolet did not provide a heater for the 27 and earlier with the single exhaust head. A heater was provided for the 1928 which is a "dual" exhaust. If you look closely, you'll notice the nail that's wedged between the manifold shroud and exhaust pipe to keep it from, I assume, making a racket.
Posts: 32 |
I like your pictures very much. My car is a 1926 roadster. I noticed you put a fuel filter before the carburetor. The vacuum tank was my biggest problem so I put the fuel filter before the vacuum tank. Maybe you did too? I know the purest would not like it but so I think I will look for sediment bulb at the next swap meet. My car has been in the family for 62 years. Dad restored but it about 35 years ago but it had sat for 10 years with out running until recently. Good luck with your car.
David Duff
Posts: 120 |
1. Is the firewall painted black or is it body color? - My car is completely black and the firewall appears to also be black.2. Is the top of the vacuum tank painted black? It is painted black, but compared to the rest of the engine compartment, this may have been repainted at some point.3. Is the oil filler tube engine color or black? It's hard to tell with all of the grime on there.4. Is the heat pipe from the exhaust to the carb painted? It doesn't look like it.5. Can you take a picture of the throttle linkage from the bottom of the steering column to the carb? There appears to be a spring where the rod connects to the carb. 6. Can you take a picture of the distributor linkage from the bottom of the steering column to the distributor? 7. Is the brass carburetor fuel bowl painted black or is it just tarnished in your picture? Polished fin, but tarnished from time and fuel.[img] https://i.imgur.com/XupXVYR.jpg[/img] 8. Is there a spring running from your carb to the firewall? Yes there is.[img] https://i.imgur.com/Q6b3f8I.jpg[/img] [img] https://i.imgur.com/cN4YmhD.jpg[/img] I hope this helps. Let me know if you need any more images. ...I noticed you put a fuel filter before the carburetor. The vacuum tank was my biggest problem so I put the fuel filter before the vacuum tank. Maybe you did too? I know the purest would not like it but so I think I will look for sediment bulb at the next swap meet.... I have a filter under the car before the vacuum tank and I have another between the tank and the carb. These are temporary and I will be replacing both of them with sediment bowls on the firewall later this year.
Posts: 120 |
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Have you cleaned the old bearings and found damage? If not I would clean and inspect and they may be re-usable. Also if you put in new ones I suggest changing both the races and the bearings.
Posts: 120 |
Have you cleaned the old bearings and found damage? If not I would clean and inspect and they may be re-usable. Also if you put in new ones I suggest changing both the races and the bearings. Yeah, the passenger side outer bearing lost all of it's balls when I took it apart. Balls also fell out one of the inner bearings.... I'm just going to replace everything. I'm in there anyways.
Posts: 120 |
Posts: 3,620 Likes: 5
Posts: 3,620 Likes: 5 |
What a fantastic car! Great work you are doing, preserving the history...
