#40354 07/07/06 02:27 AM
Dave41 Offline OP
My 59 has a 283 with 4 jet Rochester and it has a flat spot when taking off, worse when cold.
I bought a "Jet" kit but the pump plunger was too big [3/4"] mine is around 1/2"
The book says the Power Valve is probably crook.
Which one is the Power valve??
1935 Mst Roadster,1939 Norton Big 4 outfit, 1942 Buick, 1943 GPW,1959 Bel Air 2 Dr, 1963 Corvair Convert. 1956 FJ Holden Ute
Hooroo from OZ
Wilwood Engineering1955-1957
#40355 08/02/06 11:50 AM
I'm presuming your '59 has a 4GC and not a Q-jet, and that might also be why your pump plunger doesn't fit. 4GC was the standard GM 4-barrel in the late '50's to early '60's and Quadra-Jet came later.
This page has a good diagram to show what the power valve is and where it's located.
http://chevy.tocmp.com/Rochester/9D9p07.htm
http://home.comcast.net/~ps_kennedy/wsb/media/342430/site1043.JPG
#40356 08/03/06 05:16 AM
Dave41 Offline OP
Hooroo from OZ
Dave41 Offline OP
The problem appears solved, I raised the float level and I've since bought the correct kit to install,and she's running well
Hooroo from OZ
Great news - isn't it amazing what correct adjustments can do to improve performance?
