Get your reference material out and give me a hand. Car tag on right side of car on floor reads: 6 CA 03 14803, Door post (drivers) 5189, stamped in the board directly under the seat: Top line: 2020, second line 33 5 6. Car has window guide on the edge of the main glass. When window is down and vent window moved open there is no post. Car is a 6-wheel Eagle coupe, does NOT have rumble seat. What can you tell me?
6=Assembled at Oakland plant CA=1933 Eagle/Master 3=assembled in March of 1933-changeover month from Eagle to Master Vent window description indicates it is an Eagle 5189? - Fisher Body seqence number? Five window coupe a 33567 style number
I am sure you came to the same conclusion that far.
Other stamped numbers Fisher Body plant I.D. numbers?
I have kept the car 100% original as long as possible. Only problem was a very poor paint job many years ago. The car is still under 55,000 miles. Due to some battery acid damage and sun shining on the corners of the back seat rest, it has finally become necessary to take some action. I purchased a complete interior and top kit from HC and we are in the process of installing it. Also doing a firewall pad replacement. All wood is still perfect to include the top. Just a great old car the same age as me.
Posts: 317 Likes: 1
Posts: 317 Likes: 1 |
What? No pics? Come on Ray, a lot of us haven't been around here very long. Would love to see some of the cars that belong to you guys that are so knowledgeable and always so helpful here on the forum.
Jeff
1925 Superior K 4 Dr Sedan 1966 C10 2003 Silverado 1500 HD
Posts: 87 |
One other comment about the 1933 Eagle and Master 5 Window Coupes.
For 1933 only the 3 Window Sport Coupe came with a rumble seat.
The rumble seat was not an option for the 1933 5 Window Coupe, but I have seen 33 5 Window Coupe converted to have a rumble seat.
It is an easy and frequent conversion. All you need is a pair of rumble seat hinges. The existing lid is reversed, some wood removed and a few other minor things and you have a rumble seat.
