Posts: 237 |
Was the original material used on the roadster seats some sort of vinyl, leather, or a cloth material? The material on mine is cloth backed light brown vinyl, I know it is not from 1933, but i want to replace it with whatever is 'correct", as there are couple small tears in the sides of the bottom seat. Thanks, Doug ![[Linked Image from i.imgur.com]](https://i.imgur.com/T5CiWsO.jpg) ![[Linked Image from i.imgur.com]](https://i.imgur.com/IAkkYXw.jpg)
The Engineering manual says imitation leather.
Posts: 1,739 Likes: 2
Posts: 1,739 Likes: 2 |
What would be an available fabric to use to replace the original imitation leather that would pass judging standards?
Posts: 348 |
The original was called “Spanish Grain Leather” and was a sort of Olive Drab background with a range of black, tan, and orangish grain lines pressed into this imitation leather. Nobody reproduces it any longer but there are a couple of guys who have several rolls tucked away and wont let them go. Ive tried.
From a judging standpoint Ive been told to stick with a vinyl in a “period color” and you will be “fine”. My 33 phaeton is no where near jusging so I have yet to see how it all turns out.
SEARCHING FOR GOOD QUALITY 1933 CHEVROLET MASTER ORIGINAL TRICO MIRRORS FOR SIDEMOUNTS. ALL LEADS APPRECIATED.
Posts: 1,919 |
From the looks of the pictures, this is the correct material for a 33 roadster / phaeton. As Jeff said it's called "Tan Spanish Grain" and is a vinyl (Naugahyde). There are some of use diehard open car guys that have had this material made again. You can contact me for more information.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
While I am not doing a 33 I am getting closer to doing the seat in my 38 and suspect it used the same material. What remained of the old material had what looked like a clothe backing similar to modern vinyl. Is this possible or had my seat been redone before I started? Tony
Posts: 1,919 |
Tony, I can't answer your question, but know the "Tan Spanish Grain" was not used past 35. It might have been a different color. Also cabriolets in 31/32/34 were leather.
