Posts: 412 |
Anybody have any experiences to share removing and replacing spring shackle pins?
1932 Chev 5 Window Coupe
Posts: 29,848 |
Posts: 412 |
OK Thanks. I will look it up. Another question. Brake shoes. Where do most people go for these? Filling Station? Any other sources? Thanks again.
Posts: 822 |
"Where do most people go for these?"
Bert,
Parts store brake shoes sold since about 1980 are "organic" (non-asbestos). Asbestos has a higher friction coefficient than that "organic" stuff and complete shoes with asbestos linings and asbestos lining material are on ebay. When I took the "organic" friction (pads and shoes) off my '32 Ford roadster street rod and replaced it with asbestos friction from ebay it was like adding a power booster, and that is not an exaggeration.
Ray W.
Posts: 412 |
Thanks Ray! I will check to see what is available. Did you have to buy complete shoes or just the lining? Rivet them on yourself?
Posts: 29,848 |
Posts: 412 |
Thanks JD. Sounds better than sending everything away to have it done. Any suppliers for linings or just check ebay? Experience with different materials?
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
Same thing on the brake linings. Search on the forum and you’ll find your answer. The 32 didn’t use a hard molded asbestos shoe but used a woven type material I believe like the 31’, but a quick search will verify.
Posts: 29,848 |
Posts: 412 |
Great info from all. Much appreciated.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Many of the shoes I have removed from 32 Chevy brake assemblies were of molded material. Most likely they all contained asbestos which was used because of is ability to perform with the heat build up and wear well. The woven linings used today may be equal in stopping power but I do not have any data to verify that. The woven lining is used in industrial applications that require aggressive stopping power under severe high heat applications. It has been adapted for automotive use because of that ability and the discontinuance of asbestos but I do not know if it was ever used as original factory build. Would be nice to know. I have the woven lining on my 32 and it stops well and does not require excessive brake pedal pressure and actually no more than I would apply in my 2009 Silverado.
Posts: 1,919 |
If anyone is wondering what the correct Kent-Morre Spring Shackle Pin removal tool looks like let me know.
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
I would like to see it.
Thanks , Dave
Posts: 412 |
Yes. I would like to see it - thanks.
Posts: 1,919 |
LOL.... if the email notice was working I would remember to get a pictures. I'll try this weekend, sorry guys.
Posts: 29,848 |
Posts: 197 |
Regarding brake shoes. After I discovered Clutch Doctor of North Branch, MN, I quit doing them myself although I'm fully capable. If it has friction material he does it, does it well, fast and reasonably. The successor of my machine shop uses him often too. We've sent some pretty grubby looking things for relining and when they come back they look like new. https://www.yelp.com/biz/clutch-doctor-north-branch
0 members (),
91
guests, and
22
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
