Posts: 1,381 |
Does anyone have a chart that tells the AC Delco equal to the original K11 spark plug?
Posts: 654 Likes: 3
Posts: 654 Likes: 3 |
It would be C49 in Delco, but I don't know if they are discontinued. I use Champion UJ12
J Franklin
Posts: 1,381 |
Are you using that plug in a 1935 207 engine?
Posts: 654 Likes: 3
My car is a 1936 with basically the same engine. the info I gave was from the cross reference pages of a spark plug catalog.
J Franklin
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
C49 is a very hot commercial plug and has not been available from ACDelco for a long time. The current plug that seems to work well for me is the ACDelco R45 (in my 31, 39). I am presuming you are inquiring about a Chevy application, if not let us know what it is.
Posts: 1,381 |
Thanks, yes it's a Chevy. Is the heat range in a R46 too hot. I recently aquired a set.
R46 will work fine, probably very close to the right heat range.
AC still sells new 45R spark plugs. I have used them in everything with good results.
Posts: 1,381 |
Thanks all. Much appreciated.
