Posts: 49 |
I know this is not "parts wanted" section, BUT I just bought a 59 2door Bel Air Model 1611]from the US and during Restoration the Body Serial Plate was lost, Can I get one from a Wrecker Or has someone got one on a wreck ??
1935 Mst Roadster,1939 Norton Big 4 outfit, 1942 Buick, 1943 GPW,1959 Bel Air 2 Dr, 1963 Corvair Convert. 1956 FJ Holden Ute Hooroo from OZ
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
The one on the door post or the one on the cowl? John
John
Posts: 49 |
The one on the Cowl , looks like whoever repainted the car ground it off!!! the one on the door post is OK
Posts: 279 |
HI Dave, You can have a new Cowl Tag reproduced. The only problem is you do not have the "old numbers" meaing the body sequence number or the production date. The Paint and Trim numbers are easy. www.datatags.com is the only vendor I will recommend for "correctness".
Oliver J. Giorgi Technical Advisor 1958 Passenger Car
