Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
rear door garnish moulding is missing on our 39 sedan delivery. . would the garnish from a sedan or coupe interchange? thanks,mike
I doubt very much that the garnish moulding would be the same as a sedan but the back door glass is the same for a 1936-1939 sedan delivery......Garnish moulding has different part numbers though.
Posts: 812 Likes: 13
Posts: 812 Likes: 13 |
My 1940 Parts book lists #4090128 as 1939 SDDL ONLY.
Posts: 3,163 |
The difference might only be the color. Sedan delivery back door garnish moldings are not easy to find....Joe
thanks for the info guys. I'm going to a local junkyard that has a 39 2 door sedan, will get its rear window garnish mild and if it doesn't fit, perhaps I can fabricate it to fit the 39 sedan delivery. mike
Posts: 724 |
Mike...if you look on Craigslist in Dayville Conn. there's a Guy selling parts for a 37-38 SD and also the car...Billu38
