I had a Harrison heater many years back. Should still have it. Just need to locate the box where it is hiding. As I remember it was the same style but larger than the Chevy.
Posts: 67 |
Found a T fitting that might work. Spears 1401 Series PVC T fitting. 1 1/4 X 1 1/4 X 3/4. How high a temp will PVC withstand?
Enjoy when you can. Endure when you must.
As I remember it was the same style but larger than the Chevy. That is correct. The Harrison hot water heater is the same style as the 1931-32 genuine Chevrolet accessory hot water heater but only taller, and the grille is different as well.
Though not 100% correct I have several elbows that have had the heater connection welded or brazed on.
Posts: 304 |
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
Posts: 311 |
Are you going to sell any of the elbows and if so how much for one? Ron
1932 4 door Special Sedan 1916 490 Touring
