Here's a fun thread to support the lie in the subject line.
Below is a Advanced Design truck having an out of body experience.
;-) Dean
[Linked Image from i160.photobucket.com]
IT ran or YOU ran when you Parked it ??
When I hear such comments from folks you know are lying through their teeth, I always step a few paces back from them.
I don't want to be hit by lightning, as they will.
Is it just me or do others think too the fan blade clearance could be at least one problem with this restomod?
it needs wheelie bars. mike
The front tire looks a little under-inflated.
This is obviously a drag strip machine because there is a minimal capacity cooling system. So you want the front tire to offer minimum rolling resistance.
What if it runs in reverse? laugh
Anyone want to join in with their IRWIPI pictures?
I'd sure like to have a nickel for every time I've read those words (IRWIPI) when reading a craigslist ad.
That and the old "it just needs a nut on the air cleaner and it should run again".....duh, then why don't you put the nut on so that you can advertise it as a runner?
stupid
Jeff
1925 Superior K 4 Dr Sedan
1966 C10
2003 Silverado 1500 HD
Dean,
Another one is, "The air conditioner works fine, it just needs a little freon."
Thanks for your initial post. That brought a chuckle. Agrin
Just needs a battery and some gas.....
[Linked Image from stovebolt.com]
laugh Dean
That looks like it was running yesterday!
...and it comes with that rare factory accessory: Circular saw. You almost never see those.
All the Best,
Chip
"It's wise to choose a SIX"
