daves30 Offline OP
Can some one recommend a good locksmith, have a locking handle with out a key.
thank you
dave
Try Jarvis Erickson in Washington. His info. is in the G&D in the Services Offered section.
daves30 Offline OP
Will try Jarvis, thank you, if anyone else has locksmith please advise.
thanks
Many local locksmiths can make a key either from the code number or by profiling the lock. I have been told that the B&S key codes may be under Harley Davidson not Chevrolet. Code numbers are supposedly the same. I have a code book for late 20s to '34 if your locksmith can find the code.
daves30 Offline OP
Have a trunk handle without the key, the code is very clear
Also a trunk handle with matching key, however it will not move.
