Sam6779 Offline OP
GROUP,
I HAD JUST GOT A 37 CHEVY TRUCK LOCKING DOOR HANDLE OFF E-BAY. AND I NEED A KEY FOR IT. BECAUSE IT DID NOT COME WITH ONE. SO I WENT TO A REPUTABLE LOCK SHOP TO GET A KEY MADE. THE NUMBER STAMPED ON THE HANDLE SHAFT IS # 4494. THEY COULDN'T HELP. THEY SAID THAT NUMBER DOES NOT COME UP IN THERE SYSTEM. I WAS TOLD MOST OF THE LOCKS WERE MADE BY BRIGGS AND STRATTON. AND BRIGGS AND STRATTON USED 8OOO & 9000 SERIES NUMBERS. AND USED A SINGLE CUT KEY. THE LOCK IN THIS ONE HAS A DOUBLE CUT OR DOULBLE BITTED STYLE OF KEY???? I TOLD THE KEY SHOP IT WAS FROM A 37 CHEVY TRUCK. NOW I FOUND OUT IN MIGHT BE FROM A 34-35 CHEVY FROM AN OLDER POST HERE. WHICH USED A DIFFERANT NUMBER CODING. IF IT IS FROM A 34-35 CHEVY CAR OR TRUCK,........WHO KNOWS. DO I GO BACK AND TELL THEM IT'S NOT FROM A 37. IT'S FROM A 34-35 CHEVY CAR OR TRUCK. AND MAYBE SOMETHING DIFFERANT WILL SHOW UP ON THERE COMPUTER. THE APPEARANCE AND SIZE/MEASUREMENTS ARE THE SAME AS THE 37 TRUCK HANDLE WHICH I NEED. I REALLY DON'T THINK ANYBODY HAS EVER HAD THE HANDLE APART. OR CHANGED OUT THE LOCK CYLINDER. CAN ANYONE FROM THE GROUP HELP ME. OR TELL ME WHAT TO DO.
THANKS
SAM
1934 was the only year of that era that had double sided keys. Betting you have a '34 handle.
1934 key numbers went from 4000 to 4999.
Sam, try to return the lock and look for a CORRECT 37 lock. The one you have isn't correct and may not even work on a 37 truck.
See Facebook Page for Joe Fuchs to see more pictures of my 1937 Chevrolet 1/2 Ton Pickup
Look at your G&D under services. There is a guy named Jarvis out of Washington that is a lock specialist. Good luck.
Sam
If it will help, I will remove the door handle with lock from my ”˜37 1/2 Ton and take some measurements for you. I have a busy next several days, so it might take a day or two for me to get to it. Just let me know. It might help in searching for a correct fitting handle. These locking handles are scarce and usually pricey.
Sam6779 Offline OP
37 blue.......Thank's but DON'T do that. I will keep looking for now. AND thanks to all for your input.
Sam
