Posts: 929 |
http://chevy.oldcarmanualproject.com/shop/1938/38csm106.htmlWhat is the cap(secured by cotter pin) in the top image of the enclosed drive shaft? As I remove the sources of noise, I hear others so I checked fluid in tranny and rear end, both are topped off. Thank you Michael 38 Town Sedan
Posts: 929 |
Thank you. No lubing the driveshaft other than keeping the tranny and rear full?
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
It is advisable to keep that vent clear. When I do the regular oil and filter change part of the procedure is to clear any of those on the car. Tony
Posts: 84 |
There is a plug at the back of the tranny that is to lube the U-joint. The Filling Station has a tech letter on it until I read it I had know idea.
The Honer
Thee U joint is automatically lubed from the transmission. If the U joint ball is split you can pre lube the Ujoint by removing that plug other wise it is unnecessary to remove the plug.
