#399118 12/04/17 04:23 PM
DwFinch Offline OP
What degree thermostat should be in a stock 235 engine.
The 1954 trucks came with a 151 degree thermostat and a 4 pound pressure cap.
The only two thermostats available today for a 1954 is a 160 and a 180 degree. If most of your driving is done in warmer weather the 160 is fine. If a 180 is used it is best to have a 50/50 anti-freeze and water mix to raise the boiling point, especially if you drive at high altitudes.
DwFinch Offline OP
I live on the Olympic Peninsula in Wa. I will try the 180 Thermostat.
Thank you!
