#399102 12/04/17 01:34 PM
Figured I would work on getting the exhaust system cleaned up and ready to go in the car, since i am at that point. looks like the PO had a new exhaust system made / bought to replicate the original style.
I took some time to sand and clean up the surface rust and such. Then I put on a few coats of High Temp Primer Followed by a Few Coats of High Temp Exhaust Black Paint. looks a lot better than it did when it came off.
Exhaust Manifold to Muffler Primed
Exhaust Tailpipe Section Primed
Exhaust Manifold to Muffler Painted
Exhaust Tailpipe Painted
A few Close up of Muffler and other
Muffler Section
New Gasket/ Donut Installed
Took the hangers/ Brackets off and cleaned them up on Sunday. Fresh Primer and Paint to go back on.
Brackets Stripped Down
Close Up Stripped
Brackets All Primed and Painted
Close Up Painted
Thanks for the pictures.
Bob
"When an old man dies, a library burns to the ground".
No Problem, Bob
Figure IF i post pictures about what i am trying to do, I can learn what i am doing, and see if it is right, thanks to help from everyone on here, plus i can share what i did with others and hope it helps them learn/ understand, see things in regards to the 1929 I own.
Was off on Tuesday so picked up my hardware i ordered to install the Exhaust system on my 1929.
Started installation of the hangers & Brackets hoping to make it easier to install and secure.
Tail Pipe bracket & Support Installed
Another Head on Shot
Muffler Support
shadows make it look like there is a red tint, most likely from the flash...
Exhaust Manifold Mounting
Exhaust Manifold Studs Ready for Exhaust
Exhaust Pipe Mounted Up
Muffler Stapped In
Should Muffler Be SNUG in the Strapping ?? Flush up against Bracket on Frame and Strap Holding it Tight ??
