Posts: 237 |
My switch is a little funky. It could use replacement, but I don't see one listed at the Filing station.
Are these made, or do i need to search for NOS switch?
Is the Roadster pop out switch the same as any other 1933 Chev?
Thanks, Doug
Posts: 237 |
Mine has the pop out button. Does that tell you anything?
Doug
Posts: 3,163 |
From my observations it seems that the Eagle had the "pop-out" & the Master had the "on-off" switch. The Standards however had "pop-outs". I don't know if there's been any research on that subject....Joe
Posts: 3,163 |
In the March/April owners manual for the Standards it gives instructions to usage of the switch & it being a pop out design. I've read the same things you have in the parts catalogs. I know my Standard had a pop out & know of others that are or were the same. Sorry, Joe
Posts: 3,163 |
I would like to find a newer owners manual to see when they changed on the standard. Mine was built in February. Might not be a good sample. 16th sports coupe from Oakland...Joe
