hello,
we recently got a 33 master eagle everything works but3 things, the horn and the cowl lights are not hooked up. Does anyone know where on the switch should the cowl lights be hooked also the acc. switch well has no switch just a knob what should be hooked to it? Last I need a wiring diagram for the horn please.
thanks in advance!
I can't post a wiring diagram but i tell you what it says.
Power from ammeter to back of light switch, to horn, to steering column to horn button to ground. No horn relay.
The horn is not switched at teh light switch, it just gets its power from the power IN terminal on the light switch
Doug
Doug
Doug,
thanks do you have the ability to scan and email to me??
No.
It is barely readable in the book i have.
Buy a 1933 repair manual, they are cheap.
Doug
