Posts: 67 |
Having a problem getting a new fan belt installed after putting on a new water pump. Although original belt size called for is 38 1/2 inches (no longer available) I could not get a 39 inch belt over the pulley with the generator pushed all the way back toward engine block. The old belt is well used, red in color and larger. I couldn't read the info on the belt but will have it sized at the store tomorrow when I get a larger belt. Just wondering if anyone else has had this problem. Gary
Enjoy when you can. Endure when you must.
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
I just did this not too long ago on my 1929. here is the link to my post with pictures. Hopefully this helps, originally the belt I had was too long, thanks to the guys here i was able to get the correct belt.
I use 38" fractional horsepower belts from my local hardware. They fit over the pulley but have to have the generator all the way toward the engine block.
Posts: 67 |
Took my old (red) belt to the parts store to get it sized and hopefully get a replacement. They didn't have one of those tools to measure belt size. Long story short I picked up a Continental B36 belt that with a little effort I got it installed and the generator sits midway where it should. Now this belt is 36" and fits. The correct size is supposedly 38.5" and the Filling Station supplies a Gates 38" belt which I could not get over the generator pulley. Something is amiss with belt sizing but what I have now works so on to the next project.
I have used fractional horsepower belts for many years. I had been told they would not last but that proved to not be true.
