#396638 10/17/17 06:15 AM
tonyw Offline OP
I have found I will need to replace the camshaft in my 38 truck. I dont think it is a suitable candidate for regrind as it has deep pitting on or near lobe points. Chevs of the 40 list a new shaft and I was wondering if anyone has any experience with these units.
As yet the only Aus supplier I can find has not been good to deal with.
tonyw #396655 10/17/17 10:23 AM
Might be able to find one locally to regrind as well depending on the feedback on the new ones.
I have several used ones that "appear" to be in good shape but not sure if worth the shipping to you...
canadiantim #396659 10/17/17 11:06 AM
This company has been around for many years,Other than that I
Don't know much about it.... hood
HOME
CATALOG REQUEST
BLOG
E-CATALOG
ABOUT US
CUSTOMER SERVICE
MY ACCOUNT
LOGIN
SHOP FOR
Skip Navigation Links.
Expand Accessories Accessories
Expand Brake System Parts Brake System Parts
Expand Carpets & Upholstery Carpets & Upholstery
Expand Convertible Tops Convertible Tops
Expand Electrical Electrical
Collapse Engine Parts & Overhaul Kits Engine Parts & Overhaul Kits
Engine Overhaul Kits
Engine Parts
Intake and Exhaust Valves
Motor Mounts
Valve Train Kit
Water Pumps
Expand Front End Kits/Suspension Front End Kits/Suspension
Expand Fuel/Clutch Exhaust Fuel/Clutch Exhaust
Expand Other Restoration Other Restoration
Packard Parts
Expand Shock Absorbers Shock Absorbers
Expand Weatherstrip Kits! Weatherstrip Kits!
Product Detail
* This image is not exactly the same as your part. Use as a general guide only.
Product Picture
Engine Parts
Description
Cam Shaft
Each Cam Shaft is precision engineered specifically for your engine. Backed by our lifetime warranty, each part is manufactured to exacting tolerances. Restore new engine power, performance and reliability to your collector car.
Description Item # Price QTY Select
Cam Shaft 1937-1947 Chevrolet 6 Cyl - 216
07028E $225.00
per item
Questions? Please call 800-526-1096 or 973-334-9575.
ABOUT US
About Us
Our Blog: Kanter Car Tales
SHIPPING INFO
Shipping Info
Returns
Customer Service
SUPPORT CENTER
Contact Us
FAQ
Policies
PRINT CATALOG
Sign up for free print mail catalogs!
© Copyright 2017 - Kanter Auto Products, Soflex Corp. All rights reserved.
p.k.
1956 BEL AIR 2 DOOR HARDTOP
tonyw #396696 10/17/17 09:29 PM
You might try Effingham Regrinders in Effingham Il.
Honer #396699 10/17/17 09:59 PM
I would not consider a cam not made in the US and even have doubts about them also.
MANY were not hardened correctly.
Chev Nut #396707 10/18/17 05:32 AM
tonyw Offline OP
Chev Nut
That is why I am not willing to go with a regrind as the hard facing would be ground of to make my current cam usable. I found another manufacturer here in Aus so I will try to contact them tomorrow.
tonyw #396868 10/19/17 08:27 PM
I keep seeing that with the new cams, a specific breakin procedure must be adhered to, otherwise the cam may fail and there will be no warranty. It usually involves running it at 2500 RPM for twenty minutes. A friend of mine had his new 261 cam fail, some years ago.
old216 #396901 10/20/17 04:02 AM
tonyw Offline OP
I have seen postings about the break in of camshafts before (some manufacturers down here still recommend this) but I am looking for recommendation of supplier/manufacturer.
tonyw #396909 10/20/17 09:19 AM
It is generally more like running a 1500 RPM for a period of time. The higher RPM may be destructive on the othernew parts.
Years ago the new engine would be broken in with #10 oil with no fancy additives or proseedures and never gave a problem.
I NEVER SAW A 216 OR 235 ENGINE WITH A CAM LOBE WORN OFF.
It was more of a problem with almost all makes of V-8 engines years ago
Chev Nut #396945 10/20/17 05:34 PM
I meant to say in my original post that I would think this didn't happen in the factory. I guess putting in a new cam should be accompanied with new lifters, correct?
old216 #396972 10/21/17 05:15 AM
tonyw Offline OP
I had not thought of lifters but you are correct though lifters may well be easier to find than a Cam.
Noone has commented on the CoTF's cam, is it a good 1 or cheap rubbish, I still have to talk to at least 1 manufacturer down here.
tonyw #396979 10/21/17 10:00 AM
Many years ago when I had a Chevy 250 I stumbled onto a US company that could custom make a camshaft from scratch with any timing profile you could dream up.
Can't recall the name/location. All I recall was they custom made racing components and would think there would still be a market but you might have to search a bit harder. I suspect if they had the capability to perform this type of work for racing, they should also be able to make / regrind / harden a shaft properly.
canadiantim #396981 10/21/17 10:11 AM
When I recently bought a camshaft from Patricks they advised only a couple of shops are grinding almost all the old cams. A common raw casting is used for many different ones and they are then ground to the specs desired when ordered. That way they do not have a pile of finished cams sitting on the shelf hoping they have the right inventory. Instead they keep the raw casting and can grind it to the specs desired.
