Posts: 220 |
Good day everyone What is the best engine oil to use in a 1932 coupe with an original engine?
I tried searching but couldn’t find anything.
Posts: 124 Likes: 1
Posts: 124 Likes: 1 |
10w30 is recommended. Type "10w30" in search.
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
 Run 10w-30 in my 1929 bought a cheap 5 qt Super Tech to get it running and set, then just changed it out to a Name Brand of my choice for Driving :) When I get to that Point !!
Posts: 67 |
If you have been using non-detergent oil - Don't Switch unless the engine has been over hauled and all old sticky stuff removed. The Filling Station has an article on this in the Tech Section I believe.
Enjoy when you can. Endure when you must.
It is perfectly OK to use 10W-30 oil even if the engine has deposits. Dertergent will not clean a dirty engine but will prevent more gunk from forming. Just don't flush the engine with Kerosene or an engine flush as this could dislodge clumps of sludge.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
If it has had non-detergent oil all it's life I would clean out as much sludge as possible by removing the oil pan, side cover and valve cover . Also clean the screen on the oil pump and check the oil return passages on the crank front and rear. Then I would use 10-30 detergent oil.
