Posts: 208 |
Can anyone tell me how to R & R a key door for the trunk handle? Its the cover that hides the lock. I have a donor but I dont want to break it. Thank you!
Blessings Bru Deut. 7:12
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
You have to back out the drive screw. I used needle nose vice grips. Good luck.
Posts: 2,306 |
I have taken the DOOR key lids off several locks, not trunk key lids. While easy to do as described above I have had a very poor batting average reassembling them and their remaining tight. The screw seems to easily loosen. I guess the problem may be solved with a glue like JD Weld? I would not recommend disassembling them unless the lid is damaged. The lid is stainless and can be easily shined after sanding the scratches out.
Good luck, Mike
I guess the problem may be solved with a glue like JD Weld The product is "JB" weld.
The one he is referring to is part of the trunk handle. In order to re-chrome the handle it must be removed. The reason he ask the question is, his handle is bent and has another handle to replace it.
I would not use J B weld! Would make it almost impossible to remove again in the future should the need arise. A dab of blue lock tight should be ok. Or, as I did, just SLIGHTLY squeeze the opening the screw fits in, out of round so as to make for a tight fit.
