#396132 10/08/17 10:22 PM
THH Online Content OP
OP Online Content
I am in need of a 6 volt timing light but can't seem to find any? Would a 12 volt work on a 6 volt system?
Tom H.
THH #396137 10/08/17 11:13 PM
Some do, some don't. You'll have to try it. A favorite trick of mine is to drag a 12v battery out to the car along with the light and use that.
Back in the days of 6 volt systems, most timing lights were neon and didn't need the battery, so what voltage it was didn't matter. You disconnected a plug and connected the light to a little spring adapter at the plug. They were dim.
THH #396139 10/09/17 02:03 AM
When timing a 6 volt car, I always use a 12 volt timing light connected to a 12 volt battery sitting on the floor next to the car.
I'm with Skippy. I have an old 12V motorcycle battery I use -- it's much easier to lug around.
All the Best, Chip
"It's wise to choose a SIX"
Similar solution here. Typically there is a 12 volt car in the shop next to the 6 volt car so I just "borrow" 12 volts from that car.
I have a 6 volt light that i got at an antique mall, still in the box. The box shows a early 216 (no oil fill cap on valve cover). It's bright and works good.
The easiest way ? Buy a self powered timing light.
hood
p.k.
1956 BEL AIR 2 DOOR HARDTOP
Don’t know if you’re still looking, but I picked up the most basic inductive timing light Baxter Auto had in stock, and works great on 6 volt. The brand was Innova.
THH #397648 11/03/17 10:04 AM
I needed one for my 6v 1929 Chevrolet and went with this one here: INNOVA 3555 Advance Timing Light
Never had an issue using it with my 6v Battery
Can get them on Amazon for around $40 all day, well worth it !!
