Posts: 152 |
I normally do not write negative reviews unless I have conclusive evidence to prove it but I need to warn fellow car guys that Pertronix point replacement may end causing more harm than good. I installed their product in my stock 67 Nova 283 to free myself from points.. It worked fine for about 5 months and I started experiencing stalling.. I looked at everything but the ignition module until I was cruising down a highway and the ignition cutout completely for 8-10 secs and then came back on and caused a huge backfire and destroyed both of my new mufflers. I went back to points and the car has run flawlessly for the past 2 years.. $270 for new 2 new mufflers just to end up back where I started:( Mike
I know exactly what you are saying! I installed Pertronix on my 1970 Impala that I owned several years ago and it lasted one week! The Pertronix quit leaving us stranded at an intersection on a major boulevard, lead car at the stop light, on a Friday night at 5:00 and the traffic behind us was horrible! With horns honking and cars passing we had to push the car through the intersection to a parking lot at a local business. The point system is just about fool proof and easy to fix if there is a problem, which is rare. I will never, ever use a Pertronix again!
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
I can also add a Pertonix failure to the list. Luckily it was a test unit that had been on the road for nearly 3 years but in the shop as a test engine for carburetor rebuilds. The engine was running fine at a medium speed when it just quit. Testing proved it was the Pertonix. Past the 30 month warranty it was replaced with points that have worked for many more years. I also will NEVER use a Pertonix to replace an on the road fixable point setup.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
On earlier Petronix instruction sheets. it was "suggested" to store the removed points and condenser in the glove compartment. Don't recall the exact verbiage, but I thought it showed a lack of confidence in their own product.
Posts: 418 |
I agree with all of the above...have had Pertronix in small block Chevy V8's, and 409"s...I have used MSD ignitions, Mallory dual point, GM dual points, and GM single points. I have always come back to good old GM single points, set up correctly with the correct vacuum advance unit...perfect! Bobalouie
