Well, I have owned my 1937 Chevrolet truck for 38 years and here is a question I don't know the answer to.
Can someone tell me what the radiator capacity of a 1937 Chevrolet big truck radiator is?
Thank You!
See Facebook Page for Joe Fuchs to see more pictures of my 1937 Chevrolet 1/2 Ton Pickup
14 Qts. for the standard cooling system and 16 for the optional heavy duty cooling system.
Standard core is 2" and heavy duty is 3 ".
I would guess if sold in Texas the heavy duty would have been ordered.
Yes, it is the heavy duty system, and "Thank You!" for the information!
I'm going to guess about 8 quarts go in the block and about 8 quarts go in the radiator. Do you think that a reasonable guess?
Yes, that would be my guess also.
Thank you!
Wouldn't be my guess. The top tank and the bottom tank lold about a quart apiece. The flues not over 2 quarts. Those figures are a guess on my part.
I think the block holds way more than the radiator.
You could take the top and bottom hoses off and close the outlets off and fill it with quart jars of water. That would tell you the full capacity of the radiator. Of course the top tank should not be filled more than about halfway.
Further, I don't think Gene thought one through before agreeing.
