Posts: 2 |
Does anyone know of anyone who reproduces the rubber mats in the rear cargo area in the station wagons of the 50's?
Posts: 4,951 |
Have you checked with some of the "usual" places..... The Filling Station for instance: The Filling Station Or Chevs of the 40's: Chevs of the 40\'s Click on 'em and it'll take you to their 'home page.' I sure hope you check around before you just put in 'carpet' like so many folks do. Good luck!!! Bill.
The rear mat in a wagon is not rubber.It a linoleum type material.Its reproduced for Nomads ($239.00) in a vinyl but not a regular wagon.From what I undersatnd the reproduction is not too satisfactory and is full of bubbles.
Posts: 4,951 |
Gene's response (using the word linoleum) is interesting. My '57 Turquoise Nomad had the original turquoise 'mat' and I used to point out that "my car has the original 'linoleum'." I had no idea what it really was; but it looked like linoleum to me.
They used to kinda look at me with a cocked eye....'linoleum' ????
I guess I wasn't so far off afterall!!
Bill.
Wagons used linoleum with groves in it.Thats the difficult part.
Posts: 11,162 |
Just use a router with a small vee or round nose bit and a 2x4 for a guide.
Posts: 4,951 |
MM's suggestion might look as good as the re-pop stuff that Gene suggested didn't look very good. From what I undersatnd the reproduction is not too satisfactory and is full of bubbles. Actually I figure neither one would look very good!!! Too bad. I've long felt that something should be done that would look better than simply putting 'carpeting' in the 'storage area.'
Posts: 11,162 |
Probably will look as good as the original,it just depends on your skill with the router. The original was not a jewel anyway. You can use a better grade of linoleum,or you may find a commercial vinyl floorcovering that is better. The linoleum is advertised in Hemmings as Battleship linoleum.
Posts: 399 Likes: 1
Posts: 399 Likes: 1 |
Joe and Jerry, Try Cars Inc. of Michigan http://www.carsinc.com/ They have cargo linoleum for $239.00 Check it out.
