Hi Dave and Gene,
Thought I would share some updates on my progress with the kingpins on my '37 Master Coupe.
As expected, Gene's information was right on target. The floating bushings have a groove in the circumference of the OD as well as some spiral grooves in the ID. So grease does get everywhere!
My assemblies came apart very easily. All it took to drive the pins out of the axle was an aluminum punch and a 1 lb. hammer. There is some minor wear on the pins (best I can measure is about .001") and the OD of the bushings is worn maybe .002" to .003". The pin fits very snugly in the axle. The bearings do turn with some roughness.
Based on what I have read from other posts and heard from other VCCA members this is not bad at all. In the 40's & 50's I expect that most people would probably not replace these. Or at best they would replace the bushings only.
In the process of looking for replacement parts I contacted
Rare Parts . Dave might want to look there before they begin work on the knee action front end. They offer kits with oversize pins.
In fact it was a little confusing when I first saw the listing for '37 Chevy's. They show 7 kingpin kits. 3 of them are for knee action and 4 are for straight axle. And their application data is very clear about which fits which! For both designs that offer kits with standard pins as well as ones with .005" and .010" oversize pins. The 4th kit for standard axles has standard pins and oversize bushings.
I called them and talked to Leslie about the kit with oversize bushings. She was very knowledgeable and was able to tell me that those bushings were .015" oversize. That confirmed that I could not use that kit. She and I did laugh because she had to reference an older Moog hard copy catalog to determine the OD of the oversize bushings. What really impressed me is that she knew where to go and had it readily available.
Their kits are expensive compared to other sources (~$120) but they may offer a savings compared to drilling, reaming and installing sleeves.
I did find a standard NOS aftermarket McQuay-Norris kit on eBay. It should be here in a few days.
