#393015 07/31/17 11:29 AM
My shifter locks in first sometimes on my 49 fleetline. To unlock it I have to open the hood and move the two shift rods. I tried a shim by the the 2nd and 3rd arm inside, did not work Any info on this fix on some one who had this problem. LEN
You can file down the cover so the levers are not so sloppy. Also there was an aftermarket kit sold years ago with an interlock that prevented it from going into two gears at one time.
I had a similar problem and simply adjusting the linkage solved it. Most likely caused by looseness due to wear.
I had this thing years ago. if you can find one of the kits WESTERN AUTO sold years ago it will help.. but the main thing to prevent this hang up is have the clutch fully pressed all the way down before moving the gear shift. just slow down shifting out of low gear in till the clutch is pressed all the way down..
carson told you this!!
What is this kit and what is the name ????
Install ALL new shifter rod bushings, then readjust linkage rods AFTER new bushing installation.
https://www.chevsofthe40s.com/detai...d_Bushings_On_Shift_Rod_Ends_Rubber.html
sorry i don't recall the kit name .don't think they are available any more.checked FILLING STATION catalog didn't see it.
if don't move the shift lever in till clutch is fully pressed down. most likely you never have any trouble.
a rebuild of selector box is only fix.
look at this.https://www.google.com/search?q=1954+chevrolet+gear+shifter+box&tbm=isch&imgil=_uBUY9AJFMZvTM%253A%253BJeVMLIXFF6b6qM%253Bhttp%25253A%25252F%25252Fvcca.org%25252Fforum%25252Fubbthreads
there you have to weld up worn surface and file them like they where new. just slow down ,and have that clutch down then move the lever. best of luck to you..
I ordered the new bushings. Mine were worn and a little sloppy on the rods.
While all the suggetions such as clutch and bushing have some merit the worn "box" is still the problem.
see if you can see this,,
Just browsing but I remember teaching my wife in about 1956 how to open the hood and move the shift levers to correct this on my then 50 Fleetline.
