Posts: 10 |
this car just came back from the paint/body shop. So I'm lookin it over... appears they installed an aftermarket 'running board' that you see after opening the door,. with the door closed, the front of the running board is flush with the outside of the door.The rear of the running board is about 1 1/2 " out beyond the body. Is this normal ????
Posts: 406 |
Is your question about a 42 Ford?
A 1942 Ford did not have exposed running boards.?
Posts: 10 |
yes, 42 Ford 2 dr. OK, so they're not really running boards, it's the flat area under the door , sill plate (?), conceled until you open the door. Looks like a running board after you open the door. the front is flush with the door, and the rear sticks out over an inch
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
Do you realize this is a site for Vintage Chevrolets?
Posts: 10 |
So? does that mean no Chev owners know anything a bout Fords ?
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
and the rear sticks out over an inch That would not be correct. Should show the same margin all the way, front to back. Just shy of the outside edge.Google 42 Ford or search e-bay for 42 Ford. Might find a picture.
Posts: 10 |
THANK YOU !!!!! Oops, one more...would anyone know if the hood release is inside the car or out in the grill, Cuz right now there is none !.
If the car s a 1942 Ford it has an inside hood latch release.
Posts: 27 |
1941 Coupe
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Well,,,Yes. You see how much help you got, don't you. We either don't know or are ashamed to admit to any knowledge about any stinkin Ford. Charlie
