#393768 08/17/17 12:38 PM
Can someone post or send me a pic of a 1925-28 speedometer? I'd like to get one of each. My '25 is totally missing the speedo and a friend thinks he may have access to one, but he wants to know what mine should look like.
If you don't want to post you can email me jtroberts64@gmail.com
Jeff
1925 Superior K 4 Dr Sedan
1966 C10
2003 Silverado 1500 HD
Chevrolet 1925 speedometer
[Linked Image from i.imgur.com]
Chevrolet 1927
Chevrolet 1928
Fantastic Bluezone....thanks a million
Jeff
1966 C10
The 1925 & 1926 look exactly the same except one has an aluminum face ring ('26?)and the other was nickle plated.('25?)
Steve
Steve
The 28, and 29 look almost identical except the mounting brackets are slightly different. The problem is the 28 rear end ratio is I think 4.13, or 4.16, to 1, and the 29 is 3.82 to 1. So they have a difference of about 10%. That means you probably won't be able to calibrate the speedo if you use a 29 in a 28 car, and vise versa,
