#39351 02/13/05 12:32 PM
Dick55 Offline OP
Can anyone out there tell me how to fix a speedometer from jumping all over the place? Up to 40mph it works pretty good, after that it starts to jump up to 80 then back to 60 then up to 70 and you get the picture. Is there a cure for this?
Wilwood Engineering1955-1957
#39352 02/13/05 12:51 PM
Sometimes it is as simple as just replacing the cable.
#39353 02/13/05 12:53 PM
Try lubricating the speedometer cable. It sounds like it is dry. laugh laugh laugh
#39354 02/13/05 12:53 PM
Most likely it is in the speedometer cable. Take the cable loose at both ends (speedometer/transmission) and remove the inner cable. If it has residue or caked lubrication you cad clean it with WD-40. When clean, lubricate the bottom 3/4 with motor oil or very light grease. Reinstall and take it for a test drive. If the problem still exists then the speedometer must be removed, cleaned and lubricated. If you don't feel comfortable with that project it is time to send to a speedometer shop.
Agrin
#39355 02/14/05 04:33 PM
Dick55 Offline OP
Agrin
#39356 02/14/05 04:37 PM
Dick55 Offline OP
Thanks for the reply. The speedometer cable is new and lubed, so I think my problem is in the speedo head. I've never taken one apart, so I hope it's not to hard. I'm pretty good at fixing things, so I think I'll give it a try.
