#393522 08/11/17 11:14 AM
OP Online Content
Anyone have experience with Water Wetter? Water wetter is suppose to keep your engine running cooler by adding to coolant.
Michael
solafide #393525 08/11/17 01:54 PM
OK, so you have an 160 degree thermostat. The thermostat will still keep the coolant temp. at 160 Deg.
solafide #393527 08/11/17 02:18 PM
would not spend the money on it. Put some in my 40 master that was running around 180 with a 160 thermostat did nothing to help with the heat still ran at around 180.
solafide #393536 08/11/17 03:42 PM
Water Wetter is another product that I would never use. Reducing the surface tension of water has some advantages but is not the whole story. In fact your dishwashing detergent will dramatically reduce the surface tension of water. Want to put it in your old Chevy radiator?
Chipper #393544 08/11/17 07:21 PM
OP Online Content
Appreciate the advice. The upside to old questions is it introduces old topics to new members and enthusiasts. I usually try searching, but didn't this time. I can only hope others benefitted from revisiting this topic
Michael
P.S. I guess i will stick with coolant
