#392853 07/27/17 07:30 PM
piddler Offline OP
Will a Carter "W1" or "YF" work on my '54 powerglide engine?
1951 styline deluxe sport coupe w/54 engine and power glide
piddler #392859 07/27/17 08:56 PM
The bolt holes may not be the same on the manifold.
chevy1937 #392860 07/27/17 09:22 PM
The W-1 will not work because the stud holes are too close together. For the YF it all depends as that is a Universal carburtor and ,MAY have slotted mounting holes. For a 235 the holes are 2 15/16" apart center to center. The 216 is 2 11/16"
The carb. throat is also smaller for a 216.
I have a 1956 Rochester on my 1950 235 and it performs perfectly. The "bad" ones were from 1950-1952.
Chev Nut #392870 07/28/17 09:01 AM
piddler Offline OP
I had a pretty good Rochester but I stripped the screws in the shaft in the throttle body. A friend has a couple carters that I can have. I am going to rebuild the WF. If that doesn't work I will look fo another Rochester.
piddler #392892 07/28/17 09:26 PM
This list may help:
Carter YF carburetors produced for use on Chevrolet
756s … 216 engine aftermarket 1937~1952
787s … 216 engine aftermarket 1937~1952
788s … 235 engine aftermarket 1950~1952
789s … 235 engine aftermarket 1950~1952
890s … 235 engine aftermarket manual choke (number assigned, no production)
891s … 235 engine aftermarket auto choke (number assigned, no production)
964s … 216 engine aftermarket manual choke 1937~1952
965s … 216 engine aftermarket auto choke 1937~1952
966s … 235 engine aftermarket auto choke 1950~1952
967s … 235 engine aftermarket manual choke 1950~1952
2008s … 216 engine aftermarket 1937~1952
2046s … 206 engine aftermarket 1932~1936
2100s … 235 engine aftermarket manual choke 1953~1956
2101s … 235 engine aftermarket auto choke 1953~1956
2104s … 261 engine aftermarket (number assigned, no production)
3055s … aftermarket (number assigned, no production)
3211s … 235 engine aftermarket 1957~1962
3379s … 153 engine original equipment manual trans 1962~1966
3402s … 153 engine original equipment auto trans 1962~1966
3711s … 194 engine aftermarket 1962
3760s … 230 engine (number assigned, no production)
3770s … 230 engine (taxi) original equipment auto transmission 1964~1965
3771s … 230 engine (taxi) original equipment manual trans 1964~1965
3772s … 194 engine auto transmission (number assigned, no production) 1964
3773s … 194 engine manual trans (number assigned, no production) 1964
3821s … 194 engine (van) original equipment 1964
3946s … 194 engine aftermarket 1964~1965
3946s … 230 engine aftermarket 1964~1965
3975s … 230 engine (van) original equipment manual trans 1965
3976s … 230 engine (van) original equipment auto trans 1965
4043s … 194 engine (van) original equipment manual trans 1966
4043s … 230 engine (van) original equipment manual trans 1966
4044s … 194 engine (van) original equipment auto trans 1966
4044s … 230 engine (van) original equipment auto trans 1966
4048s … 230 engine (van) aftermarket experimental 1963~1966
4072s … 194 engine original equipment auto trans CALIF smog 1966
4072s … 230 engine original equipment auto trans CALIF smog 1966
4073s … 194 engine original equipment manual trans CALIF smog 1966
4073s … 230 engine original equipment manual trans CALIF smog 1966
4080s … 194 engine original equipment (pass) auto trans CALIF smog 1966
4080s … 230 engine original equipment (pass) auto trans CALIF smog 1966
4080s … 250 engine original equipment (pass) auto trans CALIF smog 1966
4085s … 230 engine original equipment (truck) manual trans CALIF smog 1966
4085s … 250 engine original equipment (truck) manual trans CALIF smog 1966
4086s … 230 engine original equipment (truck) auto trans CALIF smog 1966
4086s … 250 engine original equipment (truck) auto trans CALIF smog 1966
4145s … 194 engine original equipment (truck) manual trans 1965~1966
4145s … 230 engine original equipment (truck) manual trans 1965~1966
4202s … 250 engine (taxi) original equipment auto trans 1966
4203s … 250 engine (taxi) original equipment manual trans 1966
4278s … (export to India)
4339s … 194 engine aftermarket 1963~1967
4339s … 230 engine aftermarket 1963~1967
4339s … 250 engine aftermarket 1963~1967
4367s … 230 engine original equipment manual trans CALIF smog 1967
4367s … 250 engine original equipment manual trans CALIF smog 1967
4368s … 194 engine original equipment auto trans CALIF smog 1967
4368s … 230 engine original equipment auto trans CALIF smog 1967
4368s … 250 engine original equipment auto trans CALIF smog 1967
4369s … 230 engine original equipment (truck) manual trans CALIF smog 1967
4369s … 250 engine original equipment (truck) manual trans CALIF smog 1967
4370s … 230 engine original equipment (truck) auto trans CALIF smog 1967
4370s … 250 engine original equipment (truck) auto trans CALIF smog 1967
4371s … 230 engine original equipment (truck) manual trans CALIF smog 1967
4371s … 250 engine original equipment (truck) manual trans CALIF smog 1967
4371s … 292 engine original equipment (truck) manual trans CALIF smog 1967
4372s … 250 engine original equipment (truck) auto trans CALIF smog 1967
4373s … 153 engine aftermarket manual trans 1963~1967
4374s … 153 engine aftermarket auto trans 1963~1967
4375s … 230 engine original equipment (truck) manual trans 1967
4375s … 250 engine original equipment (truck) manual trans 1967
4376s … 230 engine original equipment (truck) auto trans 1967
4376s … 250 engine original equipment (truck) auto trans 1967
4377s … 250 engine original equipment (taxi) manual trans CALIF smog 1967
4378s … 250 engine original equipment (taxi) auto trans CALIF smog 1967
4387s … 194 engine original equipment (truck) manual trans CALIF smog 1967
4480s … 230 engine aftermarket (all Federal) 1963~1967
4480s … 250 engine aftermarket (all Federal) 1963~1967
4492s … 194 engine aftermarket 1962
6213s … number assigned no production
Jon.
