JD,
First a given. Maybe I'm just plum stupid. Yet I wonder about your response.
1. How could it be a water pump issue? If it's leaking then yes. Otherwise, please explain.
2. What does the thermostat have to do with it. Stuck closed? Then okay but It would have to be a working thermostat rated well above 180 or 190 to make it go to the red mark. Please explain you rational on this as well.
Thanks,
Charlie
BTW: To who it may concern. Me arse is still quite raw from the whopping I recently got concerning the 32. It's real hard to sit down even now. Hurts like you know what. I'm trying to do better.
BTW2. The first thing I thought on the heat problem is a partially stopped up radiator. But what do I know.
