Posts: 3,542 |
In the final stages of getting the '57 back on the road and I need some more help. The wire that goes from the heater blower should follow what route?
Posts: 1,281 |
Hey Gator. You need to buy the book, 1957 passenger factory assembly Instruction manual. This Is a must book If you own a 57 chevy. Well worth the money. The filling station has this book and I think It cost twenty dollars. The book covers everything about your 57 chevy.
The wire goes from the motor up to a U clip on the upper verticle part of the firewall towards the center.Its at about the same height as the water valve.From there it runs thru a hole in the firewall that is just above the resistor that fits into the heater duct.Should be a rubber gromet in the hole.
Posts: 3,542 |
Thanks Gene. Don, check this out: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4529131453&rd=1&sspagename=STRK%3AMEWA%3AIT I think I have bought every '57 book out there. Will check your reference to see if it shows the wire. Thanks. :)
Its shown in the accessory installation manual.Probably in the assembly manual but I didn't bother to look there.
Posts: 3,542 |
Thanks Gene. :)
