#3880 12/28/02 03:37 AM
I’m getting ready to build a steering column for my 32. The question that I have is do you put Grease or Oil in the gearbox? The gearbox housing has a grease fitting on it. The repair book calls for Heavy Oil or SAE # 160 Oil. So what is Heavy Oil? How do you put Oil in the gearbox with a grease fitting? A friend is going to use 600 weight oil in his, is this right? :(
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
#3881 12/28/02 10:15 AM
I packed mine full of wheel bearing grease since the sector pinion shaft does not have a seal to hold back oil. Also, be careful using a grease gun to fill it up. I suspect someone may have tried to pump my sector full of grease with a grease gun and cracked the housing.
#3882 12/28/02 11:41 AM
Brucie! Actually 600W and the modern 160W is pretty much the same thing. The owner's manual calls for heavy oil, everywhere, including the tie rod ends and etc. The problem with that is the oil runs out. The gear box does not have a seal, and all of the oil will run out and you will have a big puddle on your garage floor. Use chassis grease.
Also, there are grease guns that are made for heavy oil (I have one) and they can be used on grease fittings. Some equipment like bulldozers use heavy oil in the oil reservoirs for the track gears and etc. and they are filled with a grease gun containing heavy oil.
I don't think enough internal pressure can be applied with a grease gun to crack the steering box housing. laugh laugh laugh laugh
#3883 12/28/02 12:57 PM
I bought a quart of the 600 Wt. for $7.50 and checked it with my drilling mud viscosity checker and scales,and it checked exactly the same as some 80- 140 multipurpose gear lube I bought at Tractor Supply for $26 for a 5 gallon bucket. ( the label on the 600 Wt. said it had some special additives)..... So you all can do as you like, but my gearboxes on the '28 got a filling out of the 5 gallon bucket!
I do have an antique greasegun that I filled with the geargrease and use in the alimite fittings where heavy oil is called for.
I used chassis grease in the rear wheel bearings after I replaced the old felt seals with new felt seals.
#3884 12/28/02 04:16 PM
The easiest thing to do when you have the axles out is to replace the axle bearings with double sealed bearings and then you have no more worries about lubrication, or grease seals to replace either. laugh laugh laugh laugh
#3885 12/28/02 07:58 PM
Do you lube the chassis ,spring hangers, king pins ,etc. with chassis grease or 600 w ? the owners manual says heavy oil ,but will grease work ? I use the heavy oil and it does make a mess. And I have wondered if grease would work .
auto :cool2:
woody
#3886 12/28/02 08:22 PM
Use chassis grease in all of the fittings, not heavy oil, and you will do just fine. laugh laugh laugh laugh
#3887 12/28/02 08:43 PM
Junkyard Dog, You are 100 percent right. The grease works perfect and no mess. Thanks for the tip. Don :) :) chevy chevy chevy chevy :) :)
#3888 12/28/02 08:44 PM
You are welcome! laugh laugh laugh laugh
#3889 12/28/02 08:55 PM
If you have the felt wicks on the front or rear shakles like the originals then you can use the oil. If you use grease it will lessen the service life. But that will probably be many more years than you are the caretaker of an old Chevy. The other suspension parts are the same.
#3890 12/28/02 09:05 PM
Thanks guys think I will go to grease,my 31 still has the factory shakles but ,like Chip said I will never wear it out. and that will keep my paint a lot cleaner.
woody
#3891 12/29/02 03:22 AM
Hey Chip,
I've never heard of felt wicks on the front or rear shackles, could explain some more? Do they show this in the repair manual?
32 Confederate
Bruce S. DeFord
#3892 12/29/02 07:45 AM
JYD, you're right about a grease gun not developing enough pressure. I'm used to saying grease gun and meaning an air powered grease gun. Again I cannot prove it, but I suspect given the location of the crack, the thickness of the casting in the crack location and the history of the car, I suspect someone used a power grease gun to pump the sector full. That being said, the pressure built up in the sector could not be released as fast as the grease was being forced in and something had to give. Since I don't really know it is just a word of caution.
#3893 12/29/02 12:03 PM
Hey Brucie! Yep, originally the shackles had felt oil wicks, but they didn't last long and they are missing on most original worn out shackles that you find today. Also, all of the new old stock shackles that I have seen (in the original box that is) did not have the felt oil wicks included. However, several pieces of Chevrolet literature do mention these felt wicks that were used to "meter" the heavy oil that was in the hollow shackle pins to the shackle arms. laugh laugh laugh laugh
#3894 12/29/02 12:34 PM
Where are these felt wicks located? Are they stuffed inside the bore in the pin, or are they intended to be the washer-like parts that I thought were seals (located in four places per shackle).
When I bought my '31 1/2 ton, the driver's side shackle was broken from lack of lubrication. I bought a set of replacements from Obsolete Chevy. The original pins had cork washers that went between the pin and the bar (i.e. in four places). I assume these were intended to be seals. I see that Filling Station and others sell these parts in neoprene.
When I installed the '31's shackle, I used Shell Grease 33, which is used by Boeing on aircraft mechanisms. I've tested this stuff on a planetary gear head at temperatures as low as -60 F, it stayed free where the standard moly grease failed (the mechanism stopped moving because of high drag). Pretty incredable I think!
My '37 has a similar problem that I'm now trying to deal with in the best way possible. I have dreams of using the '37 as my summer driver, so I hope to put a lot of use on it.
Forrest: so why is it best to use a heavy oil? This design seems prone to wear, and without a good bearing and seal design it would seem to want a grease. The Chevrolet 1937 Specifications just say's to use "chassis lubricant" every 1000 miles. Probably Crisco oil would work if it were serviced that often!
Lenn
#3895 12/29/02 12:42 PM
Thanks for covering the answer JYD. I have looked for the references that show the felt washers but haven't found where it escaped. If you don't keep and eye on things they sneek off, just like kids.
#3896 12/29/02 01:56 PM
Well here we go again, I wonder how many points I will have deducted when my car Is judged and I do not have Felt Wicks? :) :) chevy chevy chevy chevy :) :)
#3897 12/29/02 02:02 PM
None......because the judges don't have Xray vision!!!! :eek: :eek: :eek: :eek:
#3898 12/29/02 02:33 PM
JYD, I used the felt seals because they were hanging on the shop wall next to all the cork valvecover and differential gaskets! Also I LIKE to crawl under the car with a grease gun and grease all of the jillion alimite fittings, that way I know that all of the "what-a-ma-call-its" got greased!
chevy chevy
#3899 12/29/02 11:37 PM
The reason that heavy oil is better is because it will flow (though slowly) into areas where it was squeezed or thrown out of. The shackles are subject to very high loads from bumps, chuck holes, etc. and will squeeze grease from between the pins and sockets.
Transmissions also use it because grease would not provide the proper lubrication to the gear teeth, bearings or bushings. Since the oil will flow it will provide better lubrication.
Lenn if you have the shackles with the cork or rubber seals they are not correct for '31 but are for later models. The correct shackles use hardened, tapered pins and corresponding side pieces.
#3900 12/30/02 06:09 AM
ChevyChip, you are spot on! Thanks for the lube information, I'll have to check the bearing design issues out closer as my intuition seems to be incorrect.
Sorry I've got us off-topic here, but the shackles on my '31 1/2 ton do have tapered pins and the corresponding side pieces. Since I've worked on both the '31 and '37 suspension in the last few weeks, I've gotten confused between the two... I would have sworn that the '31 also had some sort of side seal, but I just checked and you are right!
The '31 has the tapered pins and side plates as you say without seals, and the '37 has a sort of threaded pin that rides in a corresponding threaded bushing. Based on my two trucks, this later design seems to be much better for wear (it provides more bearing area, and probably retains it's lube better)... even though the '37 is worn out, at least it didn't completely eat the shackle up!
Thanks for correcting me. Not that it is important, but I am still left wondering where the felt wick is supposed to be located in the shackles.
Lenn
#3901 12/30/02 08:19 PM
I always was told (old days here) not to use grease in gear box applications as gears would just cut a channel in the grease and not pick it up as it doesn't flow back in. do modern greases flow better and so are ok for steering boxes??
they just don't make 'em like they useta
#3902 12/30/02 09:28 PM
As posted earlier, chassis grease will work just fine in your steering box. Actually, you really don't have much of a choice anyway since there are no grease seals in your steering box, any heavy oil will run out over night and you will have a large puddle on your garage floor in the morning. :( :( :( :eek: :eek: laugh
#3903 12/30/02 10:02 PM
The felt wicks are in the bottom of the depressions in the side arms.
If your steering shaft and bushings are the correct size then any loss of 600W oil is minimal. It is much the same as the transmission. Neither has seals on the shafts and will leak with lower viscosity oil.
A couple of us had a discussion today and noted that we had found minimal wear in steering gear that was filled with oil but all of those we found with grease were gobbled up. What does that tell you? :confused:
Ok, if they are worn then they will not hold oil? Maybe that is only part of the story. laugh
#3904 12/30/02 10:15 PM
As a test, a steering box was totally rebuilt with a new old stock pitman shaft, and new old stock bushings. Everything was sized correctly. The NOS bushings have a oil groove cut in them that goes to the very outside of the pitman shaft. The steering box was filled with sticky 600W from "Classitique" Products and a lot of the oil ran out overnight. As a further test, the steering box was then completely drained, and then filled with STP to the proper level. Again, a great deal of the STP ran out over night as well. If you don't want to mess with constant oil leaks on your frame, or on your garage floor, use a very smooth chassis grease and for the amount of driving that you will do, the smooth chassis grease will work just fine since most dudes are driving around with very used steering boxes anyway. laugh laugh laugh
