While working on the car, i decided to remove the Hand Brake Handle & Assembly and Refinish it.
When removed from the car, hardware was corroded and the handle had seen better days.
1929 hnad Brake Lever Assembly
1929 Hand Brake Lever Assembly Close Up 1a
1929 Hand Brake Lever Assembly Close Up 1b
1929 Hand Brake Lever Assembly Close Up 2a
1929 Hand Brake Lever Assembly Close Up 2b
Took it all apart, Blasted it in my Little Bench Top Eastwood Blaster, using 50/50 mix of Glass & Alum Ox
Brake Lever Assembly Blasted
there are some other parts in the mix as well, blasted everything while i had the machine set up !!
Primed, and then Coated all the parts... Man What a Difference !!
1929 Brake Lever Assembly Parts Painted
Brake Parts Close Up 1
Have to let paint cure, plus I had to order NEW hardware to put it all back together. so that should be here in a Few Days... I HOPE !!
