Good day everyone
My question is.....If I remove the radiator cap and look down into the top tank. Should I be able to see the hole that connects to the top radiator hose?
Bye for now
Picture from my -32 radiator
You can see the pipe from the inlet hose
You can not see the hole
[Linked Image from i.imgur.com]
Thanks Bluezone
Your picture shows exactly what I needed.
My radiator does have the exact same overflow tube, but it does not have the metal tube just above the core. I don't believe there ever was one on my radiator. Maybe that's why I have antifreeze coming out the cap when the engine gets hot.
Bye for now
